Forums >> Revit Building >> Technical Support >> Linework in linked files
Mon, Mar 12, 2007 at 1:14:12 PM | Linework in linked files
ArchWestCY
4.5 Stars: 7 Votes
I have linked 8 buildings into a campus file.  The campus file shows all of the buildings as they relate to one another.  This has worked great for several projects of this nature.  The problem I am having now is: I need the signs to show-up as dashed lines.  I can get them to be dashed lines in the family, but when I load it into the project they are solid.  I can use the linework tool in the project and the lines turn dashed (look great).  When I link it into the campus all lines are solid.  Nothing I have tried (not even filters) has any effect on the lines once the file is linked.
I am hoping that someone has had this problem before.  How did/would you fix it?
ArchWestCY
Mon, Mar 12, 2007 at 1:58:33 PM | Linework in linked files
sposton
sposton Avatar
Can you find the objects that you need to change in the Settings - Object Styles dialog, under the Imported Objects tab? That is where I would start.
HTH,
Stephen
Mon, Mar 12, 2007 at 2:22:22 PM | Linework in linked files
ArchWestCY
4.5 Stars: 7 Votes
The problem with that is these files are linked, not imported.  As far as the Object Styles goes, they are Generic Models and I have a few other pieces that are Generic Models.  If I adjusted the linework this way it would show up on all of the objects in this category.  Thanks for your time and help though.
ArchWestCY
Mon, Mar 12, 2007 at 2:33:51 PM | Linework in linked files
sposton
sposton Avatar
Ah, I see. I had recently found out that the method that I described to you works for imported AutoCAD files, so this was my immediate response. I am sure that someone here can help...unless they are all too busy beta-testing Revit Architecture 2008, that is!
Mon, Mar 12, 2007 at 4:57:03 PM | Linework in linked files
ArchWestCY
4.5 Stars: 7 Votes
I finally got it to work.
I went back to the family and setup a new sub-category for Generic Model. I called the new sub-category 'SIGNAGE'. Then I set all of the objects in the family to that sub-category, and that categories projection linetype to Dash. Then when I loaded the new version into the projects, it was dashed. I then reloaded each of the Revit Links into my campus file. All of the dashed lines came in as dashed, and I did a little dance around my desk.
Thanks for the help, and ideas.
ArchWestCY
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
linked CAD linework
Tue, Oct 22, 2013 at 3:46:11 PM
Linked Files Revit 2009
Wed, Aug 31, 2011 at 3:27:11 PM
linked files - material override?
Mon, Aug 31, 2009 at 9:59:52 AM
Page generation time: 1.2309
