Forums >> Revit Building >> Technical Support >> Instance Parameter and locked locations
Mon, Mar 12, 2007 at 10:34:43 AM | Instance Parameter and locked locations
WYSIWYG
3 Stars: 2 Votes
I made this counter with a recessed keyboard tray and and POS shelf on Friday.  Today I decided that it needed to be parametric since in projects we might want to add other millwork underneath.  I need the POS, tray and related blocking to stay together as a group.  I changed the width dimension to an instance parameter to get the shape handles and thought I was good to go.  I put it in a proeject to test it and instead of "stretching" some parts stay left aligned some right and it just slides instead of stretches.  I think it has something to do with my aligning but I'm not sure.  Help please?   Thanks!
Mon, Mar 12, 2007 at 11:41:15 AM | Instance Parameter and locked locations
WYSIWYG
3 Stars: 2 Votes
Trying to correct my model with the obvious "Edit Work Plane Left/Right" and I grouped my POS components but when I load into project it says "cant make type".  I'm stumped.
Mon, Mar 12, 2007 at 1:58:10 PM | Instance Parameter and locked locations
robinballew
robinballew Avatar
3 Stars: 4 Votes
I looked at your item.. Not quite sure what you are trying to do by designing a desk on a wall and building the wall in to the desk family..I would have the desk family as a wall based casework family. Any way assuming you know what you want I adjusted the family to work. I didn't add all the controlls that are required to make it really usefull but it will work for the most part.
BallewDesigns.com
Mon, Mar 12, 2007 at 3:10:46 PM | Instance Parameter and locked locations
WYSIWYG
3 Stars: 2 Votes
Thank you so much Robin!!!  It is relly not a wall based desk as much as it is a counter millwork item.  It is similar to a cashwrap at a retail store only we use it in casionos and it's an item we use over and over again.  I didn't want our fairly inexperienced users to have to learn to cap the "wall" with a counter (transaction top) after they inserted the millwork ("desk"Winking.  Maybe not the best approach but it will work.  My next step is modeling bars (cocktail).  Thanks again for your help!
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:48 AM
INSTANT PARAMETER SCHEDULEABLE
Wed, Jul 11, 2012 at 2:08:57 PM
Instance Shared Parameter??
Fri, Jul 11, 2014 at 2:49:26 PM
Using instance parameter in type parameter formulae
Mon, Aug 12, 2013 at 8:22:38 AM
Change Keynote to an Instance Parameter?
Wed, Jul 23, 2014 at 2:37:36 PM
Page generation time: 0.2446
