Forums >> Revit Building >> Tips & Tricks >> Setting the View for Floor Plans
Sat, Mar 10, 2007 at 10:31:17 PM | Setting the View for Floor Plans
Enginator
5 Stars: 2 Votes
I can't seem to set up a floor plan view for the 2nd story without having the floor below showing.  I want to just show a clean floor plan of each level with nothing else showing.  I've tried multiple view range settings and nothing is working.  What am I missing?
Sat, Mar 10, 2007 at 11:49:45 PM | Setting the View for Floor Plans
Enginator
5 Stars: 2 Votes
I answered my own question.  Go to View Properties and set the Underlay property to "None".  Then go to Plan Region under "View" tab to clean up areas outside of the main floor plan that may extend to the 2nd story but aren't really a part of the 2nd story.
Wed, Mar 14, 2007 at 6:11:52 PM | Setting the View for Floor Plans
Enginator
5 Stars: 2 Votes
Ok, using "plan regions" and "underlay=none" worked for everything except some stairs (as separate set of stairs - it's actually a tri-level) showing through on the upper level plan.  I tried to use linework to get rid of them, but it only gets rid of the stair lines, not the break or the "DN" annotation.  If I turn of visibility of stairs annotations, I'll lose the ones I need for the main set of stairs too.
How do I selectively get rid of below-level stair annotations?
Sun, May 20, 2007 at 8:26:43 PM | Setting the View for Floor Plans
nest
Hope this helps:
in the floor plan view, go to your Visibility window (type VV), go to stairs under the model category, click on the + sign, uncheck the box next to the text you do not wish to appear
 emilio
Enlarge Floor Plans
Thu, Feb 12, 2009 at 4:12:21 PM
12
Second Floor Floorplan Gone
Wed, Sep 4, 2013 at 8:08:55 AM
Sheet View Resolution Problem
Sun, Apr 1, 2018 at 8:18:26 AM
Revit MEP: Pipes not showing up in floor plans ??
Mon, Feb 2, 2009 at 12:04:19 PM
View range problems with framing plans
Tue, Feb 23, 2010 at 1:48:16 PM
Page generation time: 5.1935
