Forums >> Revit Building >> Tips & Tricks >> Curved/radiused Staircase
Thu, Dec 9, 2004 at 7:17:52 PM | Curved/radiused Staircase
tsynan1
Anyone know how to do a curved staircase? Something with one landing, but both runs have the same radius in the same direction.
Thu, Dec 9, 2004 at 8:49:34 PM | RE: Curved/radiused Staircase
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can use the run tool in the stair sketch by using the curved button instead of the straight section. If you require something a little more complex you can always use the boundaries and risers to sketch exactly what you need. Just remember risers must span from one boundary to the other and there can only be two boundaries...
curved walls
Wed, Oct 4, 2006 at 7:28:34 PM
Staircase help - winder staircase
Wed, Nov 28, 2007 at 4:31:48 PM
Add a nosing to a monolithic staircase
Thu, Feb 10, 2011 at 2:42:37 PM
Staircase not going to levels?
Mon, Mar 7, 2016 at 6:06:52 PM
Curved Sloping Curtain Walls....
Thu, Nov 27, 2008 at 12:37:24 PM
Page generation time: 0.0842
