Forums >> Revit Building >> Technical Support >> Stairs in plan
Fri, Mar 9, 2007 at 10:20:02 AM | Stairs in plan
Tinner
I've created stairs for all the floors in my project, but when I view them on plan I can see two sets of stair layouts.  There's one for the current plan and one from the floor below (all hidden lines) showing on the same plan.
How can I prevent the floor below from showing thru?
Sat, Mar 10, 2007 at 8:11:52 AM | Stairs in plan
robinballew
robinballew Avatar
3 Stars: 4 Votes
under the view visability you can turn off stairs and stringers below or above the cut plane..
BallewDesigns.com
Thu, Sep 27, 2007 at 2:13:20 PM | Stairs in plan
sharris2909
Where is the View visibility option located that you are referring to here in regards to the cut plane above or below?
Thu, Sep 27, 2007 at 2:20:16 PM | Stairs in plan
robinballew
robinballew Avatar
3 Stars: 4 Votes
View Visibility or Visibility Graphics (VV) or (VG) is the quick key. It is the main place where you look to turn off or adjust the View Overrides for what ever view you are in. Under the category Stairs and Under Railing you will find sub-categories to turn on and off the visibility of objects above the cut plane.
BallewDesigns.com
stairs wont demo off my plan
Wed, Aug 13, 2014 at 3:16:05 PM
Plan Region & stairs
Thu, Jun 18, 2009 at 1:28:36 PM
Cant see stairs in opening in plan view
Wed, Nov 26, 2014 at 10:35:34 AM
Stairs and plan regions (cut height)
Mon, Apr 21, 2014 at 10:22:57 AM
Revit 2020 - Stairs not showing in plan levels
Sun, May 29, 2022 at 7:23:51 PM
Page generation time: 0.4067
