14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Site Plan & Moving Building Model
I am new to revit, going through a steep learning curve to producing my first building. When I import an Autocad dwg 2d survey plan into the 'site' generated in plans, I can't find a method of rotating and placing the building correctly upon the site. (Upon moving the constraints are always numerious to resolve). I'm sure their must be a simple method and I'm attempting to locate the building incorrectly, but the revit help and tutorial menus don't seam to address this issue - can anyone explain the correct method.
Don't rotate the building, Move the site.
----------------------------------- BallewDesigns.com |
I'll try that, but I've two other quite separate buildings to locate on the site later.
If you have several building on one site I would have one file with the site and bring the buildings as a link into the site. When the buildings are linked you can move them easily.
Thanks a lot. Something worked.
Moving Building up with out moving the site |
Sun, Jul 31, 2016 at 5:20:10 PM
Same Building on Site Plan with different elevations? |
Fri, Dec 14, 2012 at 3:59:33 PM
moving a building |
Tue, Mar 18, 2014 at 9:24:59 AM
Rotating property line and site without moving building... |
Sat, Jun 15, 2013 at 10:31:20 AM
Site plan under building |
Mon, Feb 1, 2010 at 8:42:07 AM
