26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Floor to Area Ratio (FSR)
2 Posts No Rating |
Hi everyone, I am trying to create an area schedule that can calculate the Total building area at multiple floors and at the same time gives the Total Ratio (% FSR) out of the Land Area. Tricky one, Any idea how to do it???
Not sure what FSR is but you should be able to add calculated values in the schedule. When you edit the schedule click on Fields and then Calculated Value...You can add formulas to get what you need.
----------------------------------- BallewDesigns.com |
Revit will not let you use the value from one schedule in a different schedule. You have to simply define a new field and 'type' the value in on the land area to use in your floor calulations. While Revit is great, this is an area that could use some improvement.
I'd like to know how you do with this. We need to calculate floor area ratios (FAR) here, and will eventually need to do this on Revit. What does the "S" in FSR stand for (or was it a typo)? Cheers.
**Using Revit Architecture 2009, 2011, and 2012** |
plot ratio |
Wed, May 16, 2007 at 6:38:14 PM
Revit 2013: Window to Wall Ratio Schedule |
Tue, Jul 15, 2014 at 8:47:20 PM
Area Plan does not match Area from Materia/l Area |
Tue, Feb 13, 2018 at 7:50:03 AM
Gross, Rentable, and Usable Floor Area |
Mon, Jul 12, 2010 at 9:05:26 AM
tagging the surface area of a floor (revit2009) |
Wed, Mar 3, 2010 at 11:14:36 AM
