Forums >> Revit Building >> Technical Support >> Stacked Wall Proplem
Wed, Mar 7, 2007 at 8:07:29 PM | Stacked Wall Proplem
dbutterworth
I have made a stacked wall where the bottom half is wider then the top, when i try to attached it to the roof, the bottom half attaches and it deletes the top half. Can anyone help me?
Tue, Mar 13, 2007 at 7:50:43 AM | Stacked Wall Proplem
Marc9999
I've got exactly the same problem, did you have any luck finding a solution?
Fri, Dec 18, 2009 at 3:49:13 PM | Stacked Wall Proplem
MARS1276
1 Stars: 1 Votes
Make a new level.  Have the bottom half start at one elevation and end at another, then have the upper wall start at the elevation the bottom half stops at and then attach THAT to the roof.  It's great because if you want the bottom half to grow in height all you have to do is move the elevation level up (or down) and the wall behaves as it should.  Well, it did for me; I'm using 2010 by the way.
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Scheduling of Stacked Walls
Tue, Aug 18, 2009 at 2:16:01 PM
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:44 PM
Staggered Stacked Wall Join Problems
Tue, Oct 14, 2008 at 12:50:52 PM
Page generation time: 0.5398
