28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> 3dsmax to revit
9 Posts No Rating |
I figured out how to bring objects into revit from 3ds max however i have to go through arch.desktop. From arch.desktop to revit i lose all materials and details and end up with tons of lines. Is there a way to bring a complete object into revit from 3ds without distorting it and is there a way you can by pass going through arch.desktop.
as far as I know, you can't get the materials assigned in Max into Revit. I assume you already know that when you export to dwg that you have to go into ADT or ACAD to change the colors to bylayer just to get Revit to be able to put materials onto the object properly. That's my experience with it. I don't know about the lines though. Never had that problem.
Saving to 3dsMax? |
Mon, Jul 10, 2006 at 3:03:49 PM
Linking Revit to 3dsmax 9 sp1 |
Tue, Jun 26, 2007 at 11:05:38 AM
Revit to 3dsMax for GPU utilization |
Fri, Dec 21, 2012 at 12:12:35 PM
revit file too heavy when importing into 3dsmax |
Fri, Sep 11, 2009 at 1:13:54 PM
how to transform my 3d from 3dsmax into technical drawing |
Mon, Jan 19, 2009 at 1:32:51 PM
