Forums >> Revit Structure >> Technical Support >> Stuctural beam extension visibility
Wed, Mar 7, 2007 at 4:22:14 PM | Stuctural beam extension visibility
JDahl
Is there any way to control how the beam extension shows up on plan?? When I have it set to fine the beam extends to or past the support (where I want it shown), but when I switch to course, the beam extension disappears completely... We show all of our plans from course view and the beams always look like they stop way short of their support.
Thanks in advance!
Jeff
Wed, Mar 7, 2007 at 5:27:12 PM | Stuctural beam extension visibility
TomDorner
4.5 Stars: 25 Votes
You can add symbolic lines in the beam family for 'course' view, but if the beam is sloped even those symbolic lines don't show up.  It seems that the 'stick' figure lines in course view are tied to the analytical lines which stop short of the end of the beam.  There is a post over on AUGI about this and a family or two that is posted.
http://forums.augi.com/showthread.php?t=37614
Tom
www.reviteer.com   http://twitter.com/Reviteer
Beam joint extension
Fri, Jun 18, 2010 at 12:42:56 AM
stuctural columns family
Thu, Jun 14, 2012 at 11:36:47 AM
Beam System Visibility
Wed, Mar 22, 2006 at 9:23:08 AM
Automatic extension of Beam
Tue, Jan 24, 2012 at 3:24:46 AM
revit extension output : column not visible at beam end support
Mon, Aug 25, 2008 at 5:44:34 AM
Page generation time: 1.0847
