Forums >> Revit Building >> Technical Support >> Edit cut profile lineweight display issues
Wed, Mar 7, 2007 at 10:23:48 AM | Edit cut profile lineweight display issues
Sparky
5 Stars: 3 Votes
My Q is this - when editing a join with the cut profile tool everything goes fine and the join comes out perfectly. When I reopen the drawing at a later stage after saving the lineweights all go wrong. Some of the joins end up at very thick line weights and others thinner. When i select the join, edit it and quit sketch (whithout changing anything) it displays fine again for the moment - only until I print or save and close down!
Ive got cut line style overrides (override host layers in VG). Im using version 9.1
Other people in the office are experiencing the same problem.
Any help whould be greatly appreciated.
Thx in advance.
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
Edit Cut Profile
Tue, Dec 20, 2011 at 6:00:24 AM
edit cut profile
Mon, Aug 2, 2010 at 1:18:58 PM
Edit cut profile line thickness
Wed, Nov 18, 2009 at 12:15:27 PM
Edit lineweight of insulation
Fri, Nov 30, 2007 at 5:15:01 AM
Page generation time: 1.5799
