Forums >> Revit Building >> Technical Support >> rotated curtain grids?
Wed, Mar 7, 2007 at 9:13:07 AM | rotated curtain grids?
jenniferg
Hi everyone!
Does anyone know who to rotate a curtain grid?  I have an entire system that needs to be at a 45 degree angle...
Thanks!
-Jen
Wed, Mar 7, 2007 at 9:22:45 AM | rotated curtain grids?
jenniferg
I actually found it onmy own - for those who need the answer, go to an elevation view (you might not have to be in an elevation but I was having trouble in my axon views) and select the entire curtain wall.  (make sure your gird lines are not pinned.)  Select the "Configure Grid Layout" icon - looks like a torqued curtain grid.  You'll see 2 sets of info - a dimension and degree for first direction, and a dimension and degree for the second.  Type in the desired angles and you're good to go!
Hope this helps someone other than me!
-Jen
Revit sloped glazing & angled curtain grids problem
Thu, Feb 25, 2016 at 11:33:26 PM
11
Random Diagonal Curtain Grids in a Curtain Wall
Wed, Jul 6, 2011 at 6:57:03 AM
non parallel curtain wall grids
Sat, Apr 28, 2007 at 12:54:05 AM
revealing hidden curtain grid
Mon, Sep 8, 2008 at 3:55:02 PM
Way to create exterior facade on rotated curtain wall face ?
Tue, Aug 2, 2016 at 6:17:10 PM
Page generation time: 1.9076
