Forums >> Revit Structure >> Technical Support >> Plan Visibility
Tue, Mar 6, 2007 at 10:12:12 AM | Plan Visibility
Raxlux
This is visibility question in Revit Structure. When I finished roof framing I have problem in printing roof steel members with particular line weights. Problem is I can't see all the beams with same line thickness. When I previewed the faming, 20% beams are darker and rest are lighter than defined line weight.  I set up line weight 6 to all the roof beams and all the beams have same properties and same elevation. I checked visibility graphics..., Line weights and also, checked detail levels. Any idea....
raxlux
Tue, Mar 6, 2007 at 11:22:56 AM | Plan Visibility
robinballew
robinballew Avatar
3 Stars: 4 Votes
Did you check the Beam "structural usage" default is Joist i think. I usually adjust it to Girder.
BallewDesigns.com
Tue, Mar 6, 2007 at 11:41:01 AM | Plan Visibility
Raxlux
  Yes. Structural usage is " girder"...
High window visibility in plan
Wed, Aug 8, 2007 at 5:59:45 PM
Visibility in Plan View
Mon, Oct 22, 2007 at 2:40:49 PM
Room Tag is lost visibility is on
Tue, Nov 20, 2012 at 7:04:09 AM
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
Ceiling Plan & Visibility??
Fri, Dec 7, 2007 at 9:13:34 AM
Page generation time: 1.2691
