Forums >> Revit Building >> Tips & Tricks >> The Hard Way to Create a Topo Fence - But it Works.
Mon, Mar 5, 2007 at 5:06:32 PM | The Hard Way to Create a Topo Fence - But it Works.
Enginator
5 Stars: 2 Votes
There is apparently no way to create a fence that follows the topography of your site using Revit.  Here's how I did/am doing it.  Warning - this is THE hard way!
First, the type of fence I wanted to make was a 5' high wood fence.
1.  Draw reference planes along the fence lines and name them accordingly.
2.  Create temporary sections adjacent to one of the reference planes.
3.  Go to the section view and turn on "Shading with Edges".  You should now see where the "grass" meets the "dirt", or whatever defining colors there are depending on your site properties to distinguish between above and below grade.  This is now a section looking at where the fence will be, and right at the associated reference plane.
4.  Start creating the fence using Modeling->Create to extrude the components of your fence in place, following the terrain, and operating from the reference planes you inserted.  Being particularly savvy with arrays and the family browser comes in handy (I suppose, because I'm not that savvy with either).  From the section views, I also added some general terrain following reference planes for the top and bottom of the fence, from which I create the top and bottom extrusions.  You may have to switch "shading with lines" on and off in order to see what you are doing.  It's a long process, but this is a brute force method that works.
5.  I have had some success with installing Site based "post" families along a fence line, which will follow the terrain. So you could use those in conjunction with the above to better create the fence.  I don't recommend this method for all of the vertical members, because at least for a wood fence, the tops and the bottoms of the slats won't be contoured to the terrain - they will be horizontal.
Wed, Mar 7, 2007 at 8:50:55 AM | The Hard Way to Create a Topo Fence - But it Works.
robinballew
robinballew Avatar
3 Stars: 4 Votes
Can you post an image. I would like to see it.
BallewDesigns.com
Thu, Mar 8, 2007 at 12:36:52 AM | The Hard Way to Create a Topo Fence - But it Works.
Enginator
5 Stars: 2 Votes
Here you go. Rendered version isn't that great, but you get the idea.   That was my first time through.  Again, I'd probably get my sections a little closer to the reference plane next time and use site based metal posts on the inside.
Thu, Mar 8, 2007 at 6:43:10 AM | The Hard Way to Create a Topo Fence - But it Works.
I've thought about how I might approach this problem in the past and I don't know how well this would work but I know it can be done.  I know that railings, when hosted by floors, will match the floor slope.  I would do a series of narrow "floors" set to the proper slope with hosted railings built as my fence.   The floor could be my grade material.
Thu, Apr 5, 2007 at 8:12:19 AM | The Hard Way to Create a Topo Fence - But it Works.
Elmo
3.5 Stars: 4 Votes
Have you considered making the fence a site family? This was it should attach to your toposurface.
Thu, Apr 5, 2007 at 8:32:40 AM | The Hard Way to Create a Topo Fence - But it Works.
Enginator
5 Stars: 2 Votes
Yes, but the slats in a fence are usually perpendicular to sea level rather than the slope.  This creates some parametric challenges that I have no idea how to tackle.
Thu, Oct 30, 2008 at 6:37:41 PM | The Hard Way to Create a Topo Fence - But it Works.
twagnew
Just edit the profile in elevation
Fri, Dec 11, 2009 at 2:22:15 PM | The Hard Way to Create a Topo Fence - But it Works.
Chymos
Reviving an oldie.  Anyone ever figure out how to do this more efficiently.  My firm works on extremely large sites and constantly struggle with how to do fencing and street curbs on irregular topo.
Fri, Dec 11, 2009 at 2:26:29 PM | The Hard Way to Create a Topo Fence - But it Works.
I still like railings for these.  Look in the on-line library under samples and you will find a half dozen or so fence "railings".  There are other good "samples" there that you can copy clip into your project.
Fri, Dec 11, 2009 at 2:41:41 PM | The Hard Way to Create a Topo Fence - But it Works.
Chymos
I agree that this would be a great way to solve the problem on a smaller or a relatively flat site, but our sites are generally in 60 to 80 acre chunks, and seldom are they flat.  The railing solution would require a maddening number of floor slabs to pull it off well.
Mon, Nov 10, 2014 at 2:19:00 PM | The Hard Way to Create a Topo Fence - But it Works.
ans322
This post is really old but for anyone who comes across this and is still looking for a better solution, the following may help. (This was done with REVIT 2015 but it should work similarly for older versions of Revit.)
First, draw your path as you normally would. If you have a very bumpy topogrophy, I would recommend making individual segments of fence (I don't mean do each fence individually, but when you're drawing your path instead of going from 0 to 50 feet for example, go from 0 to 10, 10 to 20, etc until you hit the desired length. You'll still have one line, but you'll be able to highlight each segment individually)
With that being said, highlight your first segment. Set Slope: <drop down menu> to sloped, then set Type: <drop down menu> to custom. In the text box, indicate your desired increase in height from point 0 to your first point. Do the same for the second point, but indicate the desired increase in height from the first point. Continue until all sections have been assigned. Now, accept the changes.
If your railings follow the correct path but your balusters are in a straight line along the host level, do the following:
Select your fence and hit Edit Type under the Properties toolbox. Construction > Baluster Placement > Edit...
Note: you will only need to change the Main Pattern.
Check each baluster type in the main pattern. Look at Base: <drop down menu>. Select whichever rail you want it to follow. I generally create a bottom rail under "Rail Structure (Non-Continuous): Edit..." so that I don't have to worry about adjusting the offset.
Hit Apply, Ok, and you're good to go.
Good luck!
Fence
Wed, Jun 5, 2013 at 7:06:17 AM
Fence
Mon, Jun 15, 2009 at 11:27:20 AM
Fence
Fri, Aug 3, 2007 at 11:00:10 AM
Site fences
Sun, Sep 10, 2006 at 9:09:10 PM
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:26:25 AM
Page generation time: 0.6889
