Forums >> Revit Building >> Technical Support >> Inserting Columns
Mon, Mar 5, 2007 at 4:15:10 PM | Inserting Columns
Krbski6
1 Stars: 1 Votes
I have tried to bring in columns from my imperial library into my drawing, and everytime I do so, it doesn't recognize that I have chosen a column.  It automatically selects the last component I have chosen, such as a fireplace, etc.  Any help?  I seem to only have this problem with columns.
Mon, Mar 5, 2007 at 4:35:04 PM | Inserting Columns
Krbski6
1 Stars: 1 Votes
disregard that, im just tired.  figured it out.
Mon, Mar 5, 2007 at 4:46:36 PM | Inserting Columns
coreed
coreed Avatar
4 Stars: 16 Votes
hi Krbski6,
just want to say that in a case like this when you solve your own problem. it is good practice to post the solution of how you solved your question. as this is a learing form, i am sure that this info can be used by someone. no matter how simple it may seem after you solve the problem.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Feb 8, 2008 at 2:05:44 PM | Inserting Columns
michelle05
4 Stars: 1 Votes
I'm having the same problem.  Could you tell me how you fixed it?
Thanks,
Michelle
assigning top and base levels when inserting columns??
Thu, Dec 18, 2008 at 1:49:52 PM
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
recalcitrant columns
Tue, Aug 3, 2004 at 7:38:46 PM
Leaning columns
Sat, Jul 2, 2011 at 7:56:56 AM
Page generation time: 0.2924
