14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> The family is not of the correct category
15 Posts No Rating |
I'm trying to make some custom structural steel framing, specifically a beam stub on the face of a column. Each time I try and load a profile, I get the error about the family not being the correct type. The family is a column family to start with, but I can't load from the column family or the beam family either. I'm actually unable to load any of the families at all. I also tried one of the tutorial lessons following the exact procedure where they make a curved beam and get the exact same error, after the sweep it won't let me load anything. Any ideas?
Post the family so we can check it out.
----------------------------------- BallewDesigns.com |
Here is the beam and column family files we're using. Another fellow in our office has the trial version and he has been able to follow the tutorial and load any type of profile when I cannot.
Works fine. You might try reloading Revit...
1 Posts No Rating |
I have almost the same problem. Made a fully parameteric tappered beam with an adjustable hunch but can not load it into any project. Could anybody tell me what is wrong with it
Yeah I get the same thing, I can't load any Beam or Structure families into my current 2d sketch. It comes up with "The family is not of the correct category". Help out?
If cocky means i'm confident, There's no way i'm stopping it. |
The family is not the correct category |
Tue, Sep 12, 2006 at 8:39:41 PM
Family is not of the correct category |
Thu, Apr 13, 2006 at 1:06:25 PM
family is not of the correct category? |
Tue, Aug 23, 2005 at 10:29:45 AM
Revit 2012 The family is not of the correct category problem |
Mon, Mar 19, 2012 at 8:12:03 AM
Baluster category/sub category |
Tue, Nov 19, 2013 at 9:43:56 PM
