Forums >> Revit Building >> Technical Support >> do columns have to be centered?
Thu, Mar 1, 2007 at 5:11:42 PM | do columns have to be centered?
webb
webb Avatar
I am doing some as-builts and I need to create a column that adheres to a grid line but is not centered on it.  anyone have any ideas?
Fri, Mar 2, 2007 at 7:14:16 AM | do columns have to be centered?
This is one of the great elements in REVIT.  You can put the column in and lock its position relative to the grid or grids.  To do that, simply add a dimension from the grid(s) to the column - lock it - then if you don't want the dimension to show, delete it.  The constraint will remain unless you have chosen to remove it when you delete the dimension.
Vertical Mullion not centered in model but centered in family
Fri, Apr 27, 2018 at 9:00:50 AM
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Windows Centered to Core
Thu, Dec 7, 2006 at 9:53:26 PM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
Window Family - Keeping an Arrow Symbol Centered within a Glass Panel
Fri, Nov 18, 2011 at 1:20:30 AM
Page generation time: 0.0669
