18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Rev Clouds
27 Posts No Rating |
Hi, Is it possible to edit the apperance of the revision clouds, ie colour and arc length? many thanks in advance.
Color, yes. Arc length, only by how far you drag the line when you're making the Revision Cloud. To change the color, go to Settings >> Object Styles then under Annotation Object scroll down to Revision Clouds. Change the color, line weight etc. there. HTH!
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
brillant, thanks very much.
9 Posts No Rating |
Revit revision clouds suck! Have you figured out any way to change their appearance? I know how to change the color, but the arc lengths are what I'm disgusted with.
Revision clouds - off on one sheet but not on other sheets - is this possible? |
Fri, Mar 16, 2012 at 9:13:39 PM
RAC 2010 - Revision Block Disappears on Rev. 2 |
Thu, Jul 8, 2010 at 11:16:36 AM
Creating Revision Clouds |
Fri, Nov 13, 2009 at 6:29:50 AM
Sheet Issues/Revisions - Previous Revision Clouds Halftone |
Wed, Aug 22, 2012 at 11:03:14 AM
revit 8.1 revision tables |
Sat, Oct 29, 2005 at 10:36:13 PM
