Forums >> Revit Building >> Technical Support >> Two basic questions...
Wed, Feb 28, 2007 at 3:19:39 PM | Two basic questions...
m10allen
I have two basic questions that I do not know how to do yet. Please help with these.
1. How do you show elements above as hidden lines on your floor plan?
2. If I have a room that has a door separating it into two rooms, how do I get a Room Tag to recognize it as one room?
Thanks in advanced.
Wed, Feb 28, 2007 at 5:26:54 PM | Two basic questions...
mjpatrickid
1 Stars: 1 Votes
1. View-->Plan Region (Sketch out area to be shown and select the properties)
2. If there is a wall between those rooms it will be a room....perhaps if there is a door only you can make a door family that does not need a wall?
Wed, Feb 28, 2007 at 7:30:19 PM | Two basic questions...
archdan
3.5 Stars: 2 Votes
In response to the Second question, make the portion of the wall which hosts the door as a Non-Room bounding element.  Assuming the wall hosting the door continues outside the room or only a portion of it is to be included (i.e. 2 nested L-shaped rooms), you will have to split the wall in 2 or more pieces (again depending on what you want to define your room boundary) and change the properties for that/those segment(s).  This will prevent you from having to create a non-hosted Door Family and can be done quite easily.
Thu, Mar 1, 2007 at 8:06:29 AM | Two basic questions...
m10allen
Thanks!
Question#1
I could not get the plan region to show up, so I just drew in the lines in the plan.
Question#2
I made one of the seperating walls a non-room bounding wall, and it worked perfect.
Thu, Mar 1, 2007 at 9:32:45 AM | Two basic questions...
mjpatrickid
1 Stars: 1 Votes
Always helps to check the properties of a wall....one little check mark "Room Bounding"...good to know!
 As for the Plan Region...check your view range and Cut Plane....lets say Cut Plane is at 4'-0" but your window is 6'-0" from base...  When you create the Plan Region and go to properties (Before you finish sketch) you get a view range window again....change the cut plane to 7'-0", for example, and then finish sketch.  You should see your window after that without having to add the lines yourself.
Basic Questions
Wed, Dec 16, 2009 at 1:01:10 AM
Intro and basic questions
Tue, Apr 29, 2014 at 10:29:54 AM
Basic Roof Video Tutorials
Mon, May 10, 2010 at 8:21:12 AM
Interview Questions
Wed, May 16, 2007 at 12:31:48 PM
Complete Newbie Questions
Wed, Jun 20, 2012 at 2:39:58 PM
Page generation time: 0.1252
