Forums >> Workflow & Implementation >> Hardware >> Absolute Beginner
Wed, Feb 28, 2007 at 12:04:48 PM | Absolute Beginner
LTSA
Afternoon/Morning/Evening......
 I am a complete beginner in Revit after coming across from ArchiCAD. I have to say I am not a fan but have no choice at the moment as I am entrusted with setting this up for my company of 20 people with 4 licenses in operation to begin with. My main question is what do you guys consider the absolute minimum system to run Revit 9.1 on? I am finding things slow, cumbersome and tediously 'clunky' at the moment and fear it is our machines that are letting us down and not doing the programme justice.
Adding to this if anyone knows of anyone in the UK with revit experience looking for work to drop me an e-mail!!!
Wed, Feb 28, 2007 at 12:41:21 PM | Absolute Beginner
coreed
coreed Avatar
4 Stars: 16 Votes
i would use Autodesk's own system recomendations as a starting point
though Revit does don't take advantage of dual core processor at the moment, if you have dual core you can assign Revit to it's own and the other apps to the other.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5106033
System Requirements:
  • Microsoft® Windows® XP (Professional, Home, Tablet PC Edition) or Microsoft® Windows® 2000 SP4 (or later)
  • Intel® Pentium® 4 1.4 GHz or equivalent AMD® Athlon® processor
  • 1 GB RAM
  • 1 GB free disk space
  • 1280 x 1024 monitor and display adapter capable of 24-bit color
  • Internet connection for license registration
  • Microsoft Internet Explorer 6.0
System Recommendations:
  • Microsoft Windows XP Professional SP2 (or later)
  • Processor: Intel Pentium 4 2.8 GHz or equivalent AMD Athlon processor
  • RAM: 2 GB
  • Two-button mouse with scroll wheel
HTH
Edited on: Wed, Feb 28, 2007 at 12:41:52 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Feb 28, 2007 at 1:33:41 PM | Absolute Beginner
sposton
sposton Avatar
First of all, let me say that I have lots of empathy for you. Being forced to switch to a program that you are not comfortable with can be very...stressful (memories of Datacad...argh). As Coreed mentioned, Autodesk's system requirements should be followed, but I would absolutely recommend 2GB of RAM as a minimum. Also, your network hardware can make a huge difference. My workstation is quite fast, but our network is not. I find that working on a local copy of a workset-enabled file to be much faster than working over the network. I wish you the best in this. You are coming from a great program in Archicad, but given a little time I think that you will find yourself liking Revit quite a bit as well.
Stephen
Wed, Feb 28, 2007 at 5:06:30 PM | Absolute Beginner
mjpatrickid
1 Stars: 1 Votes
Coming across to Revit from ArchiCAD should be pretty easy...at least it was for me and I still use both.  The current version I am using of Revit (9) is a little slow...but you get used to it.  Like other former ArchiCAD users you will find features in Revit you wished you had in ArchiCAD and vice versa.  Revit is a great program though once you start really using it.... I seem to recall the first time sitting in front of ArchiCAD and wondering "What the..??!!" coming from many years of AutoCAD.
Thu, Mar 1, 2007 at 1:16:34 PM | Absolute Beginner
LTSA
many thanks all.
Mon, Mar 5, 2007 at 3:49:39 PM | Absolute Beginner
WYSIWYG
3 Stars: 2 Votes
So I went looking for a new PC on friday, specifially a lap top and I came away quite discouraged.  Seems in my area there are no XP opperating systems to be found as they have all switched over to MS Vista.  I did a quick search online from the store to see if Vista was ok and the only answer that I could find is that Vista is "not supported at this time".  I have MS ME wat home currently which cant run Revit.  What to do?
Also the salesman wanted to know what kind of graphics card (or min requirements) I needed and I couod find no information out there with this info, except for one blog about a Nividea card.  Seems as though all the "over the counter" systems are equiped with "gaming" video cards which maybe aren't the best for "graphics".  What is suggested?
He also kept recommending the Dual Core processors as all software keeps getting to need more and more power.  revit does not need this but I see that Coreed said it was ok.  Whaen i assign revit to just one of the cores can it then be used as a dual core system for other software that may need it or not?
I am able to use the offices portable liscense utility so I can do work from home on the weekends so I need a machine that can run it but I also want one that I can use for personal stuff, like Photoshop CS, etc.  Does anyone have suggestions on what would be a good home system for me that wouldn't be overkill for everything else and not break that bank??
Thanks!
Mon, Mar 5, 2007 at 4:37:19 PM | Absolute Beginner
coreed
coreed Avatar
4 Stars: 16 Votes
the new Revit Architecture 2008 is Vista ready. the key to getting older versions of Revit to run on Vista is that you must install and run as administrator, even though is is not supported by Autodesk offically.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Mar 5, 2007 at 4:44:31 PM | Absolute Beginner
WYSIWYG
3 Stars: 2 Votes
Coreed thank you!  Run as administrator on my pc even though I will not be connected to any network? Elaborate please.
Any thoughts on what type of video card is best?
thanks again!
Mon, Mar 5, 2007 at 4:45:07 PM | Absolute Beginner
mjpatrickid
1 Stars: 1 Votes
Salesman?  Suggestion: Don't purchase from sales people....or from a place like Staples or Office Depot...
Your video card will 90% of the time be shared memory (uses part of the RAM) along with allot of other "shared" hardware.  As a former salesperson at Staples, I never recommended an "out of the box" system for CAD/Graphic professionals (even though I was supposed to).
Dell still has 32/64 bit Windows XP on their workstations....and they usually have some pretty good deals..The Optiplex systems work rather well.
Since your using Photoshop as well, you may want to go a little higher than 2GB on the RAM as long as its not too much of a dent on your pocketbook.  256mb+ for the video card.  I am using ATI now.
Mon, Mar 5, 2007 at 5:00:39 PM | Absolute Beginner
WYSIWYG
3 Stars: 2 Votes
I was talking to the people at Best Buy.  I thought about specifing a machine from best buy business but wasn't sure if I had the confidence at the time to know what I was spec'ing.  that is why I'm here learning. <grin>  I see you said workstation but I was thinking laptop for portability.  Is Dell still a good choice?
Thanks again
Mon, Mar 5, 2007 at 5:14:22 PM | Absolute Beginner
mjpatrickid
1 Stars: 1 Votes
Oh no...not Geek Squad!
I have used Dell and Gateway laptops.  The 17" models are nice...but since the price of LCD's has gone down you might consider a smaller screen to gain a larger screen at home.
A place you might consider is Costco...I got an awesome deal on my home machine from there...but I was not able to customize it like at Dell's page.  So I could not ask for Office 2003 and Photoshop to be included.   Although I just looked and they have a 15.4" core2duo 2ghz with 2GB ram with a 256mb NVIDIA....and it has Office 2007 SBE....for $2300...so hey, good deals are out there
Tue, Mar 6, 2007 at 11:32:51 AM | Absolute Beginner
6slinger
1 Stars: 1 Votes
Hi
I really spent a bunch of time looking at computers and CAD systems in the summer of 2006.
When it came down to it I obviously went with Revit Smile and I looked at buying from one of the big box stores and a couple local computer stores, but no one could give me quite what I wanted.  Then I went online and looked at Dell, HP, Gateway, and XI.  They all gave me exactly what I wanted.  I decided to go with Gateway because they were not the cheapest and not the most expensive and I also know the people locally (we've bought all our computers from them) who would be doing any warranty work (if by chance anything would go wrong with it.)
Fri, Mar 9, 2007 at 10:07:16 AM | Absolute Beginner
#13
6slinger
1 Stars: 1 Votes
Hi Just thought I would drop a line to say that Dell, HP, and Gateway will still put Windows XP in preloaded if you ask for it
Absolute elevation of project
Thu, Dec 13, 2018 at 2:22:36 AM
where is my elevation on project browser?? ( beginner)
Mon, May 2, 2011 at 12:28:35 PM
Abolute Elevation and Topo Points - Revit Architecture 2009
Tue, Feb 9, 2010 at 6:02:25 PM
Absolute Newbie
Sun, Apr 29, 2012 at 8:23:44 PM
Topo surface points change from relative to absolute elevations
Thu, Apr 7, 2016 at 9:33:19 AM
13
Page generation time: 0.0230
