13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Massing printing problems
10 Posts No Rating |
Long story short. I have an unusually shaped building that I had to create using massing as standard walls would not work. I also cannot easily convert the mass to walls and roofs because of join problems. The problem I am having is that in some elevation views the mass appears normal but when I print it the mass becomes transparent and elements behind it show through. In other elevation views it works fine. Can anyone offer some help on this printing problem? By the way, show massing is turned on in all views. Thanks
Try Raster printing. I sometimes have issues with rounded items not printing correctly.
----------------------------------- BallewDesigns.com |
Thank you very much for the tip. That solved the problem and really saved me.
1 Posts No Rating |
thank you so much you also helped me with a massing roof which was coming up transparent. life saver.
13 Posts No Rating |
i don't get it..raster printing? raster processing?
Yep, you have it right, it should be rastor processing while printing rather than rastor printing.
Revit 9.1 massing not printing correctly |
Thu, Oct 4, 2007 at 11:12:47 AM
Revit Print Problems - UPDATE |
Fri, Sep 2, 2016 at 1:44:13 PM
printing problems in Revit 2013, windows 10 |
Fri, Jul 3, 2020 at 3:08:01 AM
in place massing problems |
Thu, Jul 16, 2009 at 6:41:44 AM
Conceptual Massing Problems |
Sun, Jun 28, 2015 at 10:22:44 AM
