Forums >> Revit Building >> Technical Support >> Filtering out wall sweeps
Tue, Feb 27, 2007 at 6:31:30 PM | Filtering out wall sweeps
badfish
I have an elevation that shows a trash enclosure right smack in front of a door.  I need the door to read through so I have filtered out the walls and gates that we have modeled in.  The problem lies within trying to filter out the wall sweep I have used to create the cap of the wall.  It is now time to send the project out to bid and I can't seem to get rid of that pesky sweep in elevation.  Has anyone had experience with this??
Wed, Feb 28, 2007 at 7:07:16 AM | Filtering out wall sweeps
Have you tried putting all of the items you don't want to show in a different phase?
Thu, Mar 1, 2007 at 12:01:16 PM | Filtering out wall sweeps
laurabh
Wall sweeps are a subcategory of walls in the Visibility/Graphics overrides, so you can turn them off in that particular view.
Thu, Mar 1, 2007 at 1:18:25 PM | Filtering out wall sweeps
badfish
I have several different sweeps on the building and need to keep them all on accept one.  I've tried turning off the subcategory but it hides all sweep types.
What I ended up finding to work was to change the subcategory to common lines and turn those off.  I'm not exactly sure of a reason not to do this but I am certain there is one.  The rest of the model and set od drawings did not seem to be effected.
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Schedules - filtering by view or duplicate?
Mon, Jul 28, 2014 at 8:24:36 AM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:05 AM
Page generation time: 1.1612
