Forums >> Revit Building >> Technical Support >> revolved geomtery or how to make a finial
Tue, Feb 27, 2007 at 2:21:02 PM | revolved geomtery or how to make a finial
WYSIWYG
3 Stars: 2 Votes
Does anyone know how to do a solid revolve using a profile?  I am trying to make a finial and I have already created the complex shape making it a profile family.  Now I am trying to bring that profile in make it into a finial.
I also tried doing a solid sweep but for some reason my profile is turned 90d even though I sketched in the proper quadrant when creating the profile.
Thanks in advance!
Sat, Mar 3, 2007 at 10:38:29 AM | revolved geomtery or how to make a finial
robinballew
robinballew Avatar
3 Stars: 4 Votes
Use the sweep command. If the sweep is fliped then click on the check box with Fliped. This should fix it. Post the profile if you need more help.
BallewDesigns.com
Sat, Mar 3, 2007 at 2:43:06 PM | revolved geomtery or how to make a finial
framerman
4 Stars: 13 Votes
for your finial, I would make a generic family. before you start to make your solid revolve, import your profile into one of your elevation views, i.e. front view, and place it on your vertical reference plane. then select solid revolve, make your axis on the vertical reference plane, then "draw lines", but use the pick arrow instead of the "pencil" and tab select your profile. click finish and you should have your finial
Mon, Mar 5, 2007 at 8:36:22 AM | revolved geomtery or how to make a finial
WYSIWYG
3 Stars: 2 Votes
Thank you both.  Worked fine.  Have a nice day.
hw to create a 3D star?
Sun, Oct 11, 2009 at 8:23:26 PM
Orange lines in 3D view on self-made revolved family features
Wed, Nov 25, 2015 at 7:56:21 AM
Create revolved, sloped glazing roof
Wed, Aug 1, 2018 at 8:58:23 AM
Tapered and revolved solid form
Tue, Apr 10, 2007 at 8:12:10 AM
Roof Cricket
Thu, Jun 24, 2010 at 11:34:28 AM
Page generation time: 2.4535
