Forums >> Revit Building >> Technical Support >> model text on a curved wall
Tue, Dec 7, 2004 at 10:28:47 PM | model text on a curved wall
Arthur
model text on a curved wall.... is it possible?
Wed, Dec 8, 2004 at 12:37:05 AM | RE: model text on a curved wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Model text requires a flat work plane. Two possibilities: 1. Approximate a series of reference planes around the curve and progressively select them as the work plane adding a letter at a time, 2. Use a decal as it can be hosted by a curved surface, providing you are doing a rendering... Hope this helps.
Wed, Dec 8, 2004 at 2:20:21 AM | RE: model text on a curved wall
Arthur
thanks mr spot we will try it out
Model Text on Curved Wall
Tue, Dec 21, 2010 at 7:58:21 AM
Model Text and Curved Walls
Fri, May 18, 2007 at 9:29:50 AM
Placing 3d Model Text on a Curved Wall
Sat, Nov 21, 2009 at 5:54:42 AM
Curved Model Text
Wed, Feb 8, 2006 at 3:34:25 PM
Curved Model Text
Fri, Apr 5, 2013 at 2:10:34 PM
13
Page generation time: 3.7147
