20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Color fill in area plan convering walls, furniture etc.
2 Posts No Rating |
On my floor plan the areas are color filled the colors are covering floor items such as walls, furniture people, etc. THese need to be seen in the plan as well. any ideas? revit 8.1.
You may need to explain a bit more in depth. What areas? Like room areas or areas that you define on an area plan? Can you make a screen shot and post in for us to see what's going on? Thanks and good luck!
It is not that the color fill is covering your furniture, it is that your furniture is not covering your colorfill. Many of the furniture in the standard Revit library is created with symbolic lines for plan representation with the 3D object turned off in plan view. Generally showing the 3D in plan view is a bad idea as there is too much information there for most tastes. You could edit each family and change the visisbility settings of the 3D object to appear in plan view. You could also refine those settings so the 3D shows in medium or fine resolution and set your colorfill plan to medium or fine resolution. This method would ensure that the course resolution view is preserved as symbolic lines which work best for 2D documentation printing.
Tom www.reviteer.com http://twitter.com/Reviteer |
2 Posts No Rating |
To clarify further: There is a floor plan in which everything displays fine in the floor plan view, but in the area plan view (the view where the areas are defined and color filled based on name) some of the areas that are color filled do not display correctly. In particular some of the color filled areas appear to have the color fill in front of the walls, furniture, and doors so that all you see is a block of color. None of the objects are turned off, and when you pan through the drawing the objects appear but when I stop then are covered again. there is a nearly idendtical plan in the same file that displays fine, odd. attached are both the typical plan view and the colored area plan that does not display correctly.
Area Plans with Color Fill Through Walls |
Thu, Oct 8, 2015 at 6:50:30 AM
Revit Area Plan - Furniture & walls are showing area hatch |
Fri, Mar 20, 2015 at 12:21:21 AM
Coloring an area, without coloring my furniture? |
Fri, Nov 9, 2012 at 7:46:21 AM
Color Fill Legend- only want to show one value |
Wed, Apr 22, 2015 at 7:11:49 AM
Color Fill in Building Sections |
Mon, Jun 18, 2007 at 2:35:00 PM
