Forums >> Community >> The Studio >> Hardware upgrades and Revit
Mon, Feb 26, 2007 at 12:26:30 PM | Hardware upgrades and Revit
bballew
My revit file is approaching 150 megs and navigation in the file is starting to slow way down. The model is only going to grow as more detail is added to it. I expect at this point it will be around 250 megs when its all said and done.
What I'm wondering is what hardware advances will/does revit plan to take advantage of, for performance gains.  I'm currently using 9.1. System specs are...
(2) Xeon (duel core) at 3.00ghz.
4 gigs of DDR2. (but xp only sees 3.25.)
 Nvidia Quadro FX1400
Dell Prescison 670 workstation.
What I'm hoping is that revit could in the next release take advantage of multiple cores. Any news or word on that? Also, would duel (SLI/Crossfire) videos cards give me any substantial improvements now, or in the next release? Any word one the 2008 line being Vista compatible? I'd assume it is but haven't seen anything.
Tue, Feb 27, 2007 at 6:51:42 AM | Hardware upgrades and Revit
rkitect
rkitect Avatar
4 Stars: 29 Votes
Look into the 3GB switch if your system is not already setup to use it (look in the help menu).  Then there's the typical solutions: divide it into worksets and only have the ones you need open, purge unused families (in the file menu), eliminate any captured renderings that are saved within the file, if you're working in a 3d view, turn off shading and shadows, and then the obvious; be sure you're only modeling what needs to be modeled.  Do you really need ALL of the toilets to be 3d?  This should get you started.
Let us know what works best.  Good Luck.
Tue, Feb 27, 2007 at 9:26:36 AM | Hardware upgrades and Revit
bballew
Actually. I have all of that. 3gig switch is on. The model is divided into 10 worksets and I only work in/have on the one I'm modeling in. I haven't even begun to model most of the interior, so right now there aren't any 3d objects such as toilets, sinks, etc. The interior is mainly walls with reveals/sweeps and generic models to get the elevations as close as I can to how its going to be. I've never had shadows on when modeling, for the obvious, I mainly keep it on hidden line. This model is constantly being used for final renders (in lightscape,) so the modeling needs to be as accurate as possible. Most of what is driving the size of this model right now is the detail in the custom fixtures/doors/windows, etc. I think I have some door models around 4 megs. Smile
Tue, Feb 27, 2007 at 3:29:35 PM | Hardware upgrades and Revit
rkitect
rkitect Avatar
4 Stars: 29 Votes
Then... uh... Wow. :blink:
Tue, Mar 13, 2007 at 9:17:17 AM | Hardware upgrades and Revit
cashmoter
what is the 3 gig switch?
Tue, Mar 13, 2007 at 9:22:11 AM | Hardware upgrades and Revit
coreed
coreed Avatar
4 Stars: 16 Votes
here is info in the 3G switch
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8018966&linkID=3770375
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Mar 13, 2007 at 9:38:17 AM | Hardware upgrades and Revit
rkitect
rkitect Avatar
4 Stars: 29 Votes
Info on the 3G Switch is also available in the Revit Help file and User's Manual (if you ordered it).
forced upgrades
Fri, Feb 12, 2016 at 9:07:52 AM
Hardware recommendations
Thu, Apr 25, 2013 at 8:44:38 AM
Linked File upgrades the whole time?
Mon, Jul 9, 2007 at 9:15:51 AM
the BEST hardware
Fri, May 2, 2008 at 3:02:04 PM
11
Hardware for Revit
Wed, Apr 30, 2008 at 7:31:43 AM
Page generation time: 4.1145
