Forums >> Revit Building >> Technical Support >> Linked Parameters
Mon, Feb 26, 2007 at 9:45:47 AM | Linked Parameters
afilipe
Im attempting to create a fully parametric window family with interchangeable window and transom types. The window types are interchangable with any window type preloaded into the family, as is the transom. Is there any way to link the window type parameter to the transom type parameter such that when the window width changes it changes the transom width as well?
Mon, Feb 26, 2007 at 1:20:35 PM | Linked Parameters
archdan
3.5 Stars: 2 Votes
Yes you can link parameters by selecting the component in the family and open the properties dialouge.  Once there your parameters should be visible and at the far right of each should be a small grey box where you can link to another parameter.
Can I add parameters to a linked element?
Mon, Jul 18, 2016 at 10:41:30 AM
12
Components Parameters linked to sheets templates
Wed, Aug 19, 2015 at 7:16:34 AM
Door schedule parameters not displaying "room names" from linked revit model.
Fri, May 15, 2015 at 1:22:11 PM
Scheduling Doors in a Linked file.....thought it was fixed?
Tue, Oct 5, 2010 at 3:04:11 PM
Key Schedules and Shared Parameters
Tue, Oct 7, 2008 at 3:14:43 PM
Page generation time: 1.2418
