12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Changing colors of families
1 Posts No Rating |
So here is the scoop.... I made an island family with a sink, range, and eating area. And of course I want to change the colors from the ugly flat grey. When I select the thing I want to change the color of and go to its properies and then to its material and select what I want, in this case it is the extruded object I used to fill inbetween my cabinets that I want to be cherry. Once I do that I go to the counter to make it granite, and it says it is cherry also. Everything turned cherry. And once I change one they all change to that one color. I dont get it....
If you joined teh geometry together, which it sounds like you did, then everything which is joined will have the same material (and many other properties) applied to all of the geometries. Unjoin the geometries and start to apply materials again.
Or try the paint bucket tool to apply a material to the faces of the geometry. I have not tried this but it may be worth a try. Let us know if that works.
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
14 Posts No Rating |
I would unjoin and start from there. I would create a material parameter for the objects that have similar materials, such as cabinet frames, fillers and doors. That way, if you decide to change the finish of the cabinet system, it all changes in group. It's much cleaner than joining geometry. In addition, it can apply to the balance of the cabinets, and if you make it into a Shared Parmeter, it can be used in the Finish Schedule and/or Casework Schedule...
Changing colors of downloads |
Wed, Jun 9, 2010 at 12:54:58 PM
Painting families so that colors are only visible in 3D view |
Wed, Jan 9, 2013 at 7:56:17 AM
Similar wall types with different finish colors... |
Thu, Apr 17, 2014 at 1:00:57 PM
changing object fill colors |
Sun, Oct 11, 2009 at 9:28:18 AM
Windows showing up gray in consistent colors view. |
Tue, Apr 26, 2016 at 11:25:23 AM
13
