Forums >> Workflow & Implementation >> Hardware >> Mouse Acceleration (resolution) disappears when I get into revit
Fri, Feb 23, 2007 at 12:17:32 PM | Mouse Acceleration (resolution) disappears when I get into revit
JDahl
I use a logitech trackball (trackman marble wheel) and when I switch from Acad to Revit, my mouse resolution completely changes. I can usually scroll across the screen by about a 1/2 turn of the ball but in revit it takes 5 full turns to go across... I never noticed this problem in Revit Stuctures 3 using Windows 2000, but recently got a new machine with Windows XP and we upgraded to Revit 4 at the same time, now I have this problem. Any help would be greatly appreciated! Thanks
Jeff
Fri, Feb 23, 2007 at 2:00:51 PM | Mouse Acceleration (resolution) disappears when I get into revit
JDahl
**UPDATE** With a little persistance I figured it out... I think it may be just a Logitech glitch?? But under control panel when you click mouse, it brings up logitech's mouse properties box. Under Motion where you set acceleration, there is a check box that says Disable acceleration in games... this box was checked, I unchecked it and it works fine... I guess logitech treats Revit as a Game... LOL
Fri, Feb 23, 2007 at 2:45:28 PM | Mouse Acceleration (resolution) disappears when I get into revit
framerman
4 Stars: 13 Votes
Hopefully to make you fell better, I have heard that some logitech mice seem to have problems which you probably found out yourself. My G5 doesn't seem to have any problems, but I also use the system drivers too, not the logitech ones.
Mouse Speed
Tue, Jul 19, 2011 at 4:48:43 PM
Rollover Tool Tip box does not disappear
Wed, Apr 9, 2014 at 12:09:31 PM
Screen Graphics Messed Up with Hardware Acceleration On
Tue, May 17, 2011 at 1:24:54 PM
MOUSE PROBLEM
Mon, Nov 23, 2009 at 11:08:32 AM
programmable mouse in revit....
Fri, Apr 17, 2015 at 1:41:15 PM
Page generation time: 1.5524
