10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Bulkheads
6 Posts No Rating |
How do you wrap the gyp bd at the edge of a bulkhead?
If you extend the wall down to the edge of the bulkhead how do you wrap the gyp?
If the ceiling is at your finish height at your bulkhead, then the edge of the ceiling does not show gyp bd.
For walls it says that wrapping only shows in plan view. What about showing in section or rendering?
69 Posts No Rating |
has anyone ever encountered this problem before? if so, how did you handle it? thanks for your time
Overlap the ceiling and wall so they meet perfectly at the corner. Then join geometry between them. If their layer priorites are setup correctly it will clean up correctly. HTH.
Regards,
Chris.
I'm sorry I should have read this more closely. the ceiling is at a different height from the bottom of the bulkhead, and I want the gyp board to wrap around the bottom of the bulkhead. maybe I just need to draw it with detail line.
Yes, infill this section with a wall type to match the ceiling make up.
Regards,
Chris.
Bulkheads and Tags |
Fri, May 18, 2007 at 9:26:09 AM
Bulkhead |
Mon, May 14, 2007 at 1:33:58 PM
Stepped Ceiling |
Wed, Dec 3, 2008 at 6:46:48 PM
Bulkhead |
Mon, Jun 18, 2012 at 6:38:45 AM
view range in RCP |
Wed, Apr 28, 2004 at 1:53:29 PM
