Forums >> Revit Building >> Technical Support >> BUILDING OUTLINE
Wed, Feb 21, 2007 at 11:11:43 PM | BUILDING OUTLINE
bsf
IS IT POSSIBLE TO SHOW JUST THE BUILDING OUTLINE IN SITE PLAN VIEW?
Thu, Feb 22, 2007 at 6:34:13 AM | BUILDING OUTLINE
Dgodfrey
4 Stars: 4 Votes
One way would be to draw a perimeter model line which is quite simple by tabbing till all walls are hightlit. Set the offset from the center of the wall properly and for a simple structure it works. If you have many different wall thicknesses or you can't grab them all at once, then you will need to spend a few more seconds and highlight individually. As far as an automatic visibility setting for walls to only show the finish, I suppose there may be a workaround but nothing that comes to mind.
Thu, Feb 22, 2007 at 4:47:02 PM | BUILDING OUTLINE
bsf
Thanks Dogfrey. Regards
BSF
Sun, Feb 25, 2007 at 8:02:14 PM | BUILDING OUTLINE
Rookwood
I would use Detail Lines under the Drafting Tab and trace the outline(s) you want. Create new line types to have the diversity of varying your line weights. This also works extremely well for outlining building elevations.
Model lines will show up in ALL views whereas Drafting Lines are View Specific.
Sun, Feb 25, 2007 at 8:04:29 PM | BUILDING OUTLINE
Rookwood
I forgot to mention that you need to turn off the wall visibility (and everything else you don't want to see).
Best way to show outline of building under roof on site plan
Mon, Apr 13, 2015 at 7:08:27 PM
Toposurface Outline
Mon, Jul 8, 2013 at 1:02:11 AM
Interior Elevation Bold Outline - Revit 2009
Tue, Mar 14, 2017 at 2:56:00 PM
HOW TO SHOW SUBREGION OUTLINE ON FLOOR PLAN
Mon, Jul 11, 2011 at 7:32:06 PM
Thicker Outline Lines on Elevations
Thu, Dec 28, 2006 at 10:17:41 AM
Page generation time: 0.1939
