20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Losing dimensions using linked files
23 Posts No Rating |
I have inserted a Revit file as a link into the file I am working on and my problem is when I place a dimension to something in the linked model and the dimensioned object is moved or deleted I lose my dimension. I understand why this happens (you have to dimension to something) but does any one else have this problem? Any suggested work arounds? Thanks in advanceBirdman
i think the answer to this thread may work for you also http://www.revitcity.com/forums.php?action=viewthread&thread_id=6197 HTH
Thanks that was the only solution I could come up with as well. Interesting point about the AutoCAD files moving which I was unaware of too. Thanks again,Birdman
HELP NEEDED - DIMENSIONS TO BEAMS LINKED IN FROM MULTIPLE REVIT FILES |
Mon, Jul 30, 2012 at 8:30:29 AM
Dimensioning with linked DWG files |
Sat, Nov 12, 2011 at 4:20:06 PM
Deleting Linked RVT Categories |
Fri, Feb 3, 2006 at 9:40:29 AM
autocad linked files and refresh |
Tue, Apr 7, 2009 at 2:12:36 PM
exploding linked dimensions? |
Wed, Apr 9, 2008 at 7:02:17 AM
