Forums >> Revit Building >> Technical Support >> Imported Toposurface
Tue, Feb 20, 2007 at 7:08:57 AM | Imported Toposurface
SBAssoc
I am working with Revit 9.1 and learning about toposurfaces via the book Introducing and Implementing Autodesk Revit Building which is written for Revit 8.  When I import the autocad file which has the contours set at the correct elevation Revit 9.1 has an extra step.  I select Use Imported under the toposurface sketch tools and a fly away menu comes up.  I try to use Import Instance but it will not allow me to select the imported autocad file.  It is "greyed" out as a background file.  Any suggestions?
Sat, May 5, 2007 at 3:39:33 PM | Imported Toposurface
hawk8225
I am having the same problem! Have you figured it out? If so PLEASE let mke known how you achieved this task. Thanks
toposurface problem!!!
Fri, Nov 5, 2010 at 7:40:03 AM
Toposurface
Thu, May 3, 2007 at 2:50:42 PM
toposurface
Tue, Dec 6, 2005 at 3:49:57 PM
Toposurface Using Imported Instance
Thu, Oct 2, 2008 at 1:14:01 PM
Toposurface - selecting imported instance
Tue, Sep 4, 2007 at 12:20:56 AM
Page generation time: 0.5611
