Forums >> Revit Building >> Technical Support >> How change levels in a walkthrough? (walking from 1st to 2nd story)
Mon, Feb 19, 2007 at 7:21:33 PM | How change levels in a walkthrough? (walking from 1st to 2nd story)
oscar07
I cant seem to find any info in the tutorials about changing levels during a walkthrough. How is this done?
Tue, Feb 20, 2007 at 3:19:31 AM | How change levels in a walkthrough? (walking from 1st to 2nd story)
beyondthewall
4 Stars: 3 Votes
to create a single walkthrough going to different levels, you can enter height of the camera while creating the walkthrough. when u r creating the camera path, on the top options bar u can fill in the height. i don think this option is available once u've placed the camera, u can only specify the height before putting the cam in.
Tue, Feb 20, 2007 at 7:09:53 AM | How change levels in a walkthrough? (walking from 1st to 2nd story)
You can adjust the camera after establishing the path.  I did a "drive thru" in a parking garage that included going up a ramp.
It might be interesting to go up some stairs or even an elevator.
Tue, Feb 20, 2007 at 9:21:02 AM | How change levels in a walkthrough? (walking from 1st to 2nd story)
hammer87
hammer87 Avatar
3 Stars: 4 Votes
what i do is next to the camera height box, thers a box that says level and you can change what level the cameras on but not the view.
My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087
Tue, Feb 20, 2007 at 12:07:59 PM | How change levels in a walkthrough? (walking from 1st to 2nd story)
Once you have created your walk through path, you can enter the walk through & add key frames.  Toggle to the key frames where you want to adjust your view angle.  Use F8 & adjust to your pleasure.  The walk through will interpolate between the key frames.
Mon, Dec 14, 2009 at 7:07:33 AM | How change levels in a walkthrough? (walking from 1st to 2nd story)
Dafpfy
3.5 Stars: 11 Votes
Tnx WWHub just what i needed,
F8 in walkthrough view ftw Smile
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
How to model floor joists correctly in 2 story residential
Sat, Nov 28, 2009 at 8:35:09 AM
Stairs
Mon, Aug 10, 2009 at 3:13:07 PM
list attic window as 2nd floor window in schedule
Wed, Jan 31, 2018 at 11:02:15 AM
Story and Non-story levels?
Thu, Dec 11, 2008 at 2:09:57 PM
Walkthrough - 3D orbit/change levels
Fri, Sep 19, 2008 at 6:04:56 AM
Page generation time: 2.8945
