Forums >> Revit Building >> Technical Support >> Dashed Future Walls
Mon, Feb 19, 2007 at 5:22:18 PM | Dashed Future Walls
ArchWestCY
4.5 Stars: 7 Votes
I need to show a few walls to be FUTURE BY TENANT.  Does anyone know how I can get these walls to be dashed.
I tried using Phases, and created a new phase called Future Construction, but I reached a dead-end when I couldn't get the Future Construction to show up.
Any ideas will help.
Thanks for your time.
ArchWestCY
Tue, Feb 20, 2007 at 5:36:15 AM | Dashed Future Walls
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this
http://revitoped.blogspot.com/2007/01/future-phases.html
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Feb 20, 2007 at 4:10:09 PM | Dashed Future Walls
ArchWestCY
4.5 Stars: 7 Votes
Too cool!
 I finally got a chance to work on it.  What a great tool.  I'll have to let my friends in on this one.  The one part of this process that was a bit difficult is the overlay.  I was trying to do this with the underlay tool in the view properties.  Eventually, I figured out that you are supposed to put both views on one sheet of paper. Then, it worked great.  One more tip, the order that you put your views on the sheet matters.  For the best result, I put the New Construction plan on the sheet first.  Then I put the Future Construction view on top of that.
It is so easy to change a wall from New to Future or visa versa.
My office is a buzz with excitement for this new tool.  Thanks for pointing me in the right direction.
ArchWestCY
walls below floor are not dashed
Mon, Apr 27, 2009 at 4:38:31 PM
Future Phase
Fri, Dec 22, 2006 at 1:57:07 PM
Make lines of walls dashed?
Tue, May 4, 2010 at 10:03:23 AM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
How to show structure below dashed
Tue, Jan 10, 2006 at 9:27:02 PM
11
Page generation time: 4.3763
