Forums >> Community >> The Studio >> Rotating a 4x4x1/4 angle
Mon, Dec 6, 2004 at 4:31:42 PM | Rotating a 4x4x1/4 angle
Kirk
How do you rotate a structural angle 4x4x1/4. I can flip the face but I can not rotate the angle. for instance this --------- - - - - to this - - - - -------------- Thanks lol
Mon, Dec 6, 2004 at 5:25:55 PM | RE: Rotating a 4x4x1/4 angle
RevitChild
the easiest way that I think there is, is to mirror it along one of it's sides and rotating it.
Tue, Dec 7, 2004 at 8:30:40 AM | RE: Rotating a 4x4x1/4 angle
Kirk
The mirror command does not work if you try and mirror a structural angle from one of its sides. The only way that I have found is by creating a structural family that has the angle rotated the correct way that I need in the drawing. (label the angle LLV or LLH)
Tue, Dec 7, 2004 at 5:26:06 PM | RE: Rotating a 4x4x1/4 angle
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When you place a structural object, it is associated to a work plane, typically a level. In section if you draw a reference plane at the angle you with the structural angle to be at, and set this as the work plane then draw in the structural component. This should give you what you need. Unfortunately as a structural component the structural capabilities are associated to the workplane and as such cannot be rotated in a conventional manner.
Mon, Mar 28, 2005 at 9:15:29 PM | RE: Rotating a 4x4x1/4 angle
softfirm
very frustrating, but i too have had to create another family with the angle pointing the other direction.
Thu, Apr 27, 2017 at 12:39:01 PM | Rotating a 4x4x1/4 angle
Jesusl
Resolved in 2016 or higher (possibly earlier).  There is a cross-section rotate in the properties under constraints.  Hope this helps.
Mon, Jan 14, 2019 at 9:04:14 AM | Rotating a 4x4x1/4 angle
hanbyjm
Helped me, thank you Jesus! Smile
Rotating Items on X-axis
Wed, May 25, 2011 at 12:56:39 PM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
angled railing (not ramp or stair angle)
Fri, Jan 20, 2017 at 12:27:41 PM
Rotating Objects in Elevation/Section
Tue, Jan 27, 2009 at 8:17:15 AM
Getting angle parameter for a plywood fill region detail component to work SMART
Wed, Jan 15, 2014 at 7:27:39 AM
Page generation time: 0.6353
