Forums >> Revit Building >> Technical Support >> Ramp Problem
Mon, Dec 6, 2004 at 3:49:29 AM | Ramp Problem
ale02
ale02 Avatar
3 Stars: 3 Votes
Hi, all. We noticed that once a ramp is created, we can rotate the riser line but not change the riser line into an arc line, What happen is we need to change the base riser line to be an arc shape. Any ideas on how should we go around this? Thanks first!
Life is never easy but nor it should be complex. Just stay simple Smile
Sat, May 14, 2011 at 12:09:45 PM | Ramp Problem
Luigiman
Did you ever figured out how to change the shape of the riser line in a ramp to an arch? I am getting an error when I close the Sketch mode.
Thanks
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
Stair-ramp-landing Problem
Mon, Mar 24, 2014 at 11:13:25 AM
RAMP TAG FAMILY FOR RAMP NAME
Mon, May 9, 2016 at 6:49:09 AM
Ramp Slopes
Thu, Jun 4, 2015 at 3:19:33 PM
Ramp and Topo surface problem Revit 2014
Thu, Oct 9, 2014 at 8:36:16 PM
Page generation time: 2.1888
