18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> new user question on ceiling plan view
2 Posts No Rating |
I want to draw a ceiling plan with joists and rafters with the floor plan walls showing underneath either in hidden lines or lightly shaded. If I'm in the ceiling plan view with the first floor underlay on, drawing with lines results in the message about not being able to see the work in this view and check the view range. After all kinds of different view range settings, I still can't see the lines I draw. I also find it very bewildering to be told my depth of range is lower than my top cut plane which is an error. Any help? thanks.
I think you would be better off if you made a new level for your joists and rafters. ceiling plans are reflected. I'm not sure what the concept of the view ranges are on RCP's though. lines might be turned off in the visibility
Edited on: Fri, Feb 16, 2007 at 7:32:54 PM
Ceiling plan view... No Doors? |
Wed, May 16, 2007 at 1:52:37 PM
Reflected ceiling plan question |
Sat, Feb 28, 2009 at 9:10:53 AM
Ceiling View Ranges: 2 |
Sat, Feb 23, 2008 at 9:25:24 PM
Problem seeing doors in reflected ceiling plan |
Mon, Jul 14, 2008 at 9:26:12 AM
How to make a floor plan level into a ceiling level plan in Revit MEP |
Tue, Apr 12, 2011 at 7:09:06 AM
