Forums >> Revit Building >> Technical Support >> Cut into Topography
Thu, Feb 15, 2007 at 7:52:09 PM | Cut into Topography
jberri
How to amend a sloping topographic surface to accommodate a new structure below the natural ground level
with cut and fill information. The Pad command does not provide cut and fill information.
The Graded Region command distorts the topography, we are not able to produce a clean vertical cut into the ground.
What are we doing wrong? can someone help?  many thanks
Mon, Feb 19, 2007 at 8:55:23 AM | Cut into Topography
I've not worked with extracting cut and fill information but I do have a couple of ideas that may help.
Have you tried adding some spot elevations to control your graded regions. There is no reason why you can't add a control point along an existing contour at the contour elevation. You can then add another spot right next to it but xx' apart in vertical elevation.  By doing this at each contour line in the affected area, you can have a graded region with near vertical cuts.
I think you may want to try multiple phases - One phase to cut for the building and extracts the cut/fill information - and a final grading phase that uses pads for your final model.
Please let us know what finally works for you.
Edited on: Mon, Feb 19, 2007 at 9:57:56 AM
Cut graphics for topography
Tue, Jun 12, 2012 at 1:27:06 PM
Topography Cut/Fill Schedule
Thu, Nov 16, 2006 at 11:15:51 AM
Visibilty of cut topography in section views
Sun, May 3, 2009 at 2:55:28 AM
splitting topography
Wed, Jan 19, 2005 at 8:36:37 PM
Revit Topography Cut Hatch only shows up under Building Pad
Fri, Feb 24, 2017 at 11:31:36 AM
Page generation time: 0.3908
