Forums >> Revit Building >> Technical Support >> Crop Region Line Weight
Thu, Feb 15, 2007 at 11:04:55 AM | Crop Region Line Weight
grayd
Is it possible to change the lineweight of the crop region?  For example, to achieve a thick border around an interior elevation.  I wasn't able to find an option in the Settings>Object Styles menu, where I thought it might be.  Thanks!
Thu, Feb 15, 2007 at 1:45:18 PM | Crop Region Line Weight
coreed
coreed Avatar
4 Stars: 16 Votes
i don't think you can change the lineweight of the crop region. but you should be able to trace over it with a lineweight of your of your choosing
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Nov 24, 2008 at 10:32:53 AM | Crop Region Line Weight
jmqrsq
5 Stars: 3 Votes
I know this an old thread, but in 2009 and maybe others you can select the crop region and right click and override object by element, but what I see from that it shows by default "by object style"... I cannot figure out if there really is an object style that affects this or not. I can tell you though that the override by element works great!
Crop Region Line Control [ 1 2 ]
Wed, Mar 30, 2016 at 3:49:59 PM
18
crop region - elevations
Fri, Oct 23, 2009 at 12:43:33 PM
Viewport bounding box line weight
Tue, Feb 9, 2010 at 10:58:16 AM
Changing Lineweight of Crop Regions
Mon, Jun 19, 2017 at 8:39:07 AM
filled region boundry line weight?
Tue, Jul 25, 2006 at 1:18:07 AM
Page generation time: 0.4677
