Forums >> Revit Building >> Technical Support >> Building Orientation on a site
Thu, Feb 15, 2007 at 8:29:04 AM | Building Orientation on a site
mvan1
I have created my building to the point that i need it at and began working on the site.  How do I get the building oriented to the site the way I need it, without rotating the floor plans views or messing up elevation angles.  I am very new to Revit and currently training myself, I would appreciate the help in any way possible. Thanks.
Thu, Feb 15, 2007 at 10:07:42 AM | Building Orientation on a site
TomDorner
4.5 Stars: 25 Votes
Look at the Revit help file and tutorials for rotating a project and view to 'true north'.
The other option is to create the site in a serperate Revit file and link the building file into the site.  This is the method I use as it makes it easy to rotate the building to any angle.  Especially helpful early in the planning stages when you just want to play with where and how the building sits on the site.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Site Orientation
Fri, Jul 1, 2005 at 3:52:38 PM
Linked Revit model not importing in the correct orientation
Fri, Nov 20, 2015 at 4:00:35 AM
Linking Building to site
Mon, Jan 5, 2009 at 1:41:36 PM
Multiple buildings & orientations on same site
Wed, Jul 16, 2014 at 10:35:49 AM
Imported Site into Building Model issue
Fri, Jun 27, 2008 at 11:11:54 AM
Page generation time: 3.3372
