Forums >> Community >> Newbies >> Creating a BIM tutorial p. 47 of 91.
Wed, Feb 14, 2007 at 2:21:42 PM | Creating a BIM tutorial p. 47 of 91.
professor960
So, I'm onto the tutorial listed above, I'm only 4 days into the software, so bear with me.
I get to item #32 on p. 47 it says to "select the newly created curtain wall panel and unpin it"  no idea how to select the panel itself (in order to insert a door) as the illustration shows.  I'm only able to select the mullion(s).
Am I missing something? VG maybe. but there's no mention of that on the tutorial.
Is anyone familiar with this tutorial and can give me some tips.  The BIM is a 6 level retail tower, if that helps.
Thanks!
Wed, Feb 14, 2007 at 2:27:43 PM | Creating a BIM tutorial p. 47 of 91.
TomDorner
4.5 Stars: 25 Votes
Hover your cursor near the edge of a panel and press the TAB key to select the curtain panel.
Alternately, go to an elevation view and do an 'inculsive' selection window [lower left to upper right] and get the curtain panel and other objects if they are close and use the 'filter' button to just use the curtain panel.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, Feb 14, 2007 at 2:38:37 PM | Creating a BIM tutorial p. 47 of 91.
professor960
The "window" selection tool worked, i then filtered out the mullions like you said.
Thanks for a quick response!
Is there any good "Creating Families" tutorial?
Thu, Jul 2, 2009 at 3:26:15 PM
manufacturer to do BIM object creation
Fri, Dec 26, 2014 at 2:55:03 PM
What BIM course should I apply for? I already use BIM for 7 years.
Thu, Jun 15, 2017 at 6:43:58 AM
BIM Question: Doesn't creating a 3D metal roof with window wall mullions-------
Mon, Mar 14, 2005 at 4:18:58 PM
Seeking Typical Cost of BIM Consultant
Wed, Aug 3, 2011 at 12:16:16 PM
Page generation time: 1.7897
