18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> multiple curved/ arc and straight joined path line issues
Has anybody a message prompt stated cannot create sweep and/ or cannot join sweep message when you create multiple joined curved/ arc/ straight joint path lines in solid and void sweep? Why is the limitation here? sometime it works but most time it fails! I was planning to use this to chamfer some of my furniture family on the edge but come to a roadblock here Thanks in advance
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
I have run across this several times, and for several different reasons I might add. The most common is that the profile comes to close to the edge (tangential to one or more surfaces) of a solid being cut, and same issue can occur with all types of Void geometries. This is particularly true when the profile is also curved and is being swept along a curved path or along a curved solid geometry. The other most common cause for this is that the profile is larger then the radius of the curved path. I.E. you are trying to chamfer off 3" and your sweep radius is only 2". HTH.
Edited on: Wed, Feb 14, 2007 at 6:34:15 PM
Arc Walls with curved top? |
Thu, Aug 7, 2008 at 2:04:21 PM
Curved/Arc Grid Line - NOT DASHED |
Thu, Oct 13, 2011 at 11:22:19 PM
3D Path / Profile View ( Curving Reference Plane ) |
Mon, Apr 14, 2008 at 1:07:44 PM
Array along a curved path |
Tue, Nov 11, 2014 at 9:11:45 AM
Arc Lines display as straight lines |
Sun, Jun 12, 2011 at 10:07:46 AM
