Forums >> General Discussion >> Revit Project Management >> Renaming a Central File
Mon, Feb 12, 2007 at 10:42:29 AM | Renaming a Central File
Letmethinking
How can I rename a Central File?
Mon, Feb 12, 2007 at 10:58:11 AM | Renaming a Central File
Open it and do a save as with the "make this a central file" checked works for me.
Mon, Feb 12, 2007 at 11:59:28 AM | Renaming a Central File
Letmethinking
Thanks Dude, Then Can I delete the other safely?
Tue, Feb 13, 2007 at 5:08:34 AM | Renaming a Central File
mibzim
Yep - make sure you remake your local files from the new central file though, otherwise they will be saving back to the old central!
Renaming of the Architect's Central File
Tue, Dec 29, 2009 at 7:13:54 PM
detach from central file
Wed, May 12, 2010 at 12:28:23 PM
can't save as a central file
Wed, Sep 9, 2009 at 2:35:47 PM
Opening a File Detached From Central
Wed, Oct 25, 2006 at 4:06:42 PM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:53 PM
Page generation time: 1.4373
