13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Revit & Vista
5 Posts No Rating |
How can I get Revit Installed on Vista?
this is from AutodesK http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8991785&linkID=5495515 HTH
Edited on: Mon, Feb 12, 2007 at 11:59:00 AM
admin
I tried installing the latest build of 9.1 this weekend and can confirm that it does not work on Vista. Has anyone with 10 beta tried installing on Vista?
Pierced Media, LC |
sucks for me, since in couple of months im getting a laptop-by then hopefully thell have the problems sloved. most likely by then Vista will be standard
Revit 9.1 does work on Vista. Autodesk say they don't support it yet for a good reason. The way you need to get it on your machine take's a little bit know how. You need to first enable your administrator account. You need to then install as the administrator and when you want to run the program you need to run it as administrator.
6 Posts No Rating |
I have tried to run the program as administrator and I still can't get it to work. I get a message saying that Autodesk Revit has stopped working. I donwloaded the latest version of the Revit 9.1 from the Autodesk website and I don't really want to upgrade to 2008 at the moment. Can anyone help?
6 Posts No Rating |
I have been having exactly the same difficulty. I have installed 2 different versions of Revit 9.1, as the administrator and they still don't run when I right click and select 'run as administrator' I have also been into compatibility mode and selected run in XP which doesn't work either. Any ideas?
Revit 2010 & Vista UAC |
Thu, Oct 1, 2009 at 3:19:34 PM
HP DESIGN JET 1050C FOR VISTA 64 BIT |
Fri, Apr 18, 2008 at 6:39:35 PM
Is it VISTA? |
Fri, Jul 25, 2008 at 10:10:45 AM
12
Revit files that cannot be deleted in vista |
Tue, Mar 24, 2009 at 3:33:39 PM
revit keyboardshortcuts.txt issues on Vista? |
Wed, Sep 3, 2008 at 8:56:44 PM
