Forums >> Revit Structure >> Tips & Tricks >> Keynotes Rock !
Thu, Feb 8, 2007 at 9:08:59 PM | Keynotes Rock !
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I recently spent a little time digging into the Keynotes aspect of REVIT 9 and I have to say.
Wow ! That was far too easy. Why is everyone not using these?
Below is a link to a CADclip on how easily you can put Keynotes to work and gain a ton of time.
(right click and 'Save Target As.." to download)
I've also included a sample image of what I did with Keynotes.
Fri, Mar 2, 2007 at 2:07:50 PM | Keynotes Rock !
SGdpadilla
Thanks for posting this link.  What would be even greater is if Autodesk would rename "keynote" to "keyed note" and end decades of this term being improperly used :-(
Newish Revit User :-)
Fri, Mar 2, 2007 at 2:24:33 PM | Keynotes Rock !
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Agreed !
This would explain why most people simply breeze by the topic becasue 'keynote' doesn't trigger the correct thinking.
'Key Notes' creates a clear mental depiction of 'notes' that are 'keyed'. HELLO !
DG
Thu, Mar 8, 2007 at 6:31:21 AM | Keynotes Rock !
SteveB
3.5 Stars: 5 Votes
Does one have to add the information to each item for it to keynote?  If you have meticulously a structural plan, made of elements which have properties including a type value that identifies it accurately ("W10x29"Winking, do you have to select each element and then assign the keynote? there are a daunting number of (smart?) elements in a building, you have to go in a keynote every one to use keynoting???
(there should be...) Is there a master table of keynotes that can be selected in settings>kenoting that already knows what all the elements are (since almost all revit building components already have plenty of info about themselves? )
Thu, Mar 8, 2007 at 9:17:32 AM | Keynotes Rock !
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Steve, that is a regular Tag (by catagory) not a keynote. And yes it is all built in.
Thu, Mar 8, 2007 at 2:30:59 PM | Keynotes Rock !
SteveB
3.5 Stars: 5 Votes
What tag woud be used for structural members, Cryingwhat folder is it in?)
Thu, Mar 8, 2007 at 2:32:02 PM | Keynotes Rock !
SteveB
3.5 Stars: 5 Votes
...and I have no idea why these emoticoms keep dropping into me posts.
Sun, Mar 18, 2007 at 11:59:27 AM | Keynotes Rock !
BearValleyDesign
dgcad has hit a home run with his Keyed Notes lessons!  That's just what I was looking for.
Way to go Daryl!
Need really a good looking rock material!
Mon, Sep 1, 2008 at 2:04:24 AM
rock veneer wall
Sat, Feb 23, 2008 at 9:53:02 PM
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
Page generation time: 0.8958
