Forums >> Revit Systems >> Technical Support >> Crop Region Shapes
Tue, Feb 6, 2007 at 8:04:06 PM | Crop Region Shapes
Moose
1 Stars: 4 Votes
Hi,
Can anyone tell me if you can change the shape, other than a rectangle or sqaure, of a crop region? For all those ex-AutoCAD users, a bit like the polyline view port feature. Some of the guys use white filled regions to block out unwanted sections but I feel this is asking for trouble. Thanks
Wed, Feb 7, 2007 at 9:59:18 AM | Crop Region Shapes
TomDorner
4.5 Stars: 25 Votes
Only rectangular crop regions available.  This has been a wish list item for many years.  White filled regions are the work around.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Sun, Dec 13, 2009 at 4:47:58 PM | Crop Region Shapes
ollienz
ollienz Avatar
Hi Guys,
these comments were posted 5 years ago - anyone know if subsequent versions have included this feature, and if so how to utilise it? thanks in advance...
Mon, Apr 2, 2012 at 12:41:29 PM | Crop Region Shapes
esahnow
I'm using Revit Arch 2012 and have the same issue. Is the masking region still the way to go?
Eric Sahnow
Project Lead/Designer
Mon, Apr 2, 2012 at 12:48:55 PM | Crop Region Shapes
I rarely use masking regions.  I prefer to use the linework tool and the edit cut profile tool.
Mon, Apr 2, 2012 at 12:51:17 PM | WWHub
esahnow
Quoting WWHub from 2012-04-02 12:48:55
Can you please expand on this technique? One downfall I always hate about the masking region is that it doesn't cover up annotations, dimensions, grid lines, etc.
Eric Sahnow
Mon, Apr 2, 2012 at 1:00:52 PM | Crop Region Shapes
Why would you want to cover up an annotation?  If you don't want to see it, don't place it.
Bothcut profile an linework tool are very well documented with visual examples in your HELP.
crop region changes when placed on sheet
Fri, Jan 9, 2015 at 3:33:07 PM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:29 PM
crop region - elevations
Fri, Oct 23, 2009 at 12:43:33 PM
Room Tags Outside Crop Region
Sun, Sep 10, 2006 at 8:05:26 PM
datum controls and crop region
Fri, Oct 13, 2006 at 4:43:25 PM
Page generation time: 1.5255
