Forums >> Revit Systems >> Technical Support >> Drawing past its end
Tue, Feb 6, 2007 at 6:01:55 PM | Drawing past its end
tmarchitects
how do you open an existing drawing that gets a prompt that says the following
"attempt was made to access the drawing past its end"
Justin
Wed, Apr 25, 2007 at 12:06:09 PM | Drawing past its end
mssdynamix
We had this same problem in our office a week ago.  Here is the responce that we received...
User Menugdelfs
Joined Tue, Apr 3, 2007 2 PostsNo rating
When trying to save to central or access the central file we recieve this error.
An attempt to access 060153 Central.rvt past its end.
Has anyone seen this before? Does anyone know of any solutions/causes for this? I don't want to lose the work we have done in our individual "save as" links. Please help.
Thu, Apr 19, 2007 at 7:18:07 PM | Central file past its end
Post Menu#2
User MenuMr Spot
site moderatorMr Spot Avatar
Joined Mon, Jan 12, 2004 2084 Posts5 Stars from 3 Votes
Unfortunately "past its end" is one of the worst errors you can come across.
Contact Autodesk support and see if they can repair the file, but most likely it will be unrepairable.  Best bet is to find a local file or a backup that you can open that has the least missing information...
I can't remember what the cause of this error is either...
Regards,
Chris.
IT/CAD Manager/Senior Designer
Wed, Apr 25, 2007 at 1:16:33 PM | Drawing past its end
gdelfs
4.5 Stars: 3 Votes
Since the error occured fairly early in the morning, we just replaced the file with the previous days back-up.
Wed, Aug 8, 2007 at 11:59:12 AM | Drawing past its end
Jtouchstone
5 Stars: 2 Votes
Does anyone know what causes this error I have a File that it keeps happening to.
Thu, Apr 17, 2008 at 1:21:32 AM | Jtouchstone
StephA
Quoting Jtouchstone from 2007-08-08 11:59:12
"Does anyone know what causes this error I have a File that it keeps happening to."
Hi, did you ever receive an answer to your question about what causes the "attempt was made to access xfile.rvt past its end"?
Thu, Apr 23, 2009 at 3:48:52 PM | Drawing past its end
LaxBrad
Once this message is recieved the current file is completely corrupt. This error can be caused by crashing the program or "ending the task" while it is trying to save. The best thing to do is go back into a bak. file, and attempt to send the crashed file to Autodesk. In some cases the bak. files can be corrupted as well, in which case your only option is to "save as" a couple different files of the same drawing. Hope this helps...
Thu, Mar 20, 2014 at 3:17:49 PM | Drawing past its end
agdjdoel
Thank you,
I was thinking the same thing. That for some reason it was corrupt. We had issue with this central file, as one of our designers started to work on the central file instead of the local file.
So we had to make a her central but it wouldn't because her file was out of date.
Thanks, for the quick response.
Revit City Rocks
extend railing past end post.
Wed, Dec 30, 2009 at 5:00:04 PM
Thu, Apr 19, 2007 at 6:18:07 PM
metric mass.rft past its end
Sun, May 12, 2013 at 1:26:45 AM
Error Message
Wed, Oct 10, 2007 at 10:46:59 AM
File is "past it's end"
Wed, Dec 19, 2007 at 9:35:12 AM
Page generation time: 2.1153
