Forums >> Revit Building >> Technical Support >> Column disappers in detail view
Tue, Feb 6, 2007 at 12:40:25 PM | Column disappers in detail view
burke424
I have structural columns inserted in my floor plan which are inside of walls and visible. When I go to the detail call out view to finish the detailing the wall is hiding hte column. How do I get the columns to show in detail view?
Tue, Feb 6, 2007 at 1:12:24 PM | Column disappers in detail view
burke424
Never mind. I found the check box for "Show family pre-cut in" in the family catagory and parameters of the column.
Fri, Jan 9, 2009 at 3:36:44 PM | Column disappers in detail view
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
I was having the same issue and that indeed did the trick but is there any downside to deselecting that option?
The wording of it doesn't make much sense 'show family pre-cut in plan views'. What does that have to do with it not showing up in detail views?
Thanks
It's got to be happy hour somewhere
Mon, Jan 12, 2009 at 9:27:29 AM | Column disappers in detail view
burke424
I have not seen any down side to changing this setting. I'm still not sure what the wording actually means but it fixed our problem.
Mon, Jan 12, 2009 at 9:35:19 AM | Column disappers in detail view
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
Fixed ours too. Thanks for sharing that info.
structural column visability
Thu, Sep 8, 2011 at 1:14:26 PM
plan detail callout in section [ 1 2 ]
Fri, Mar 29, 2013 at 12:48:11 PM
15
Column Visibility in Callout Detail
Tue, Dec 23, 2008 at 4:28:47 AM
Lineweight of steel column in coarse view
Fri, Jan 7, 2011 at 6:25:48 PM
Creating an Enlarged Detail View of a Detail I have Drawn
Fri, Aug 31, 2012 at 7:05:29 AM
Page generation time: 2.2580
