Forums >> Revit Building >> Technical Support >> Stair Shaft with independant landings not tied to each floor level
Mon, Feb 5, 2007 at 3:29:09 PM | Stair Shaft with independant landings not tied to each floor level
Rakel
I want to be able create a landing at each floor along with the intermediate landing.  I do not want to edit the floor profile to butt up against the beginning riser.  I have say a poured concrete fire stair shaft, say each floor is 15' apart.  I can I create the landing at each level?  I have used the multi-level stair command, and have been able to create the stairs and the intermediate landings, but not the landing at the floor level.  HELP.  why can't this be done.
Mon, Feb 5, 2007 at 6:58:32 PM | Stair Shaft with independant landings not tied to each floor level
framerman
4 Stars: 13 Votes
is it possible to post a screenshot from the side view? Just trying to get a clearer picture of the problem. I'm not positive, but you might have to adjust your floor edit lines to make the landing, or just create a new floor there to make your landing
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Stair Up/Down Arrows
Thu, Dec 6, 2012 at 2:08:47 PM
Can You Change a Family's Type?
Wed, Mar 5, 2014 at 10:33:16 AM
3 run stair case w/ 2 landings
Tue, Apr 3, 2012 at 2:44:18 PM
13
Stairs - Multistory Monolithic Rev 2014
Mon, Dec 30, 2013 at 8:48:35 AM
Page generation time: 0.9981
